Temperature-Dependent Modeling
Many manufacturing and other engineering applications require a thermal component to the material characterization. Thermal analyses and mechanical analyses involving temperature sensitive mechanical properties of polymers and other advanced materials frequently require a multi-physics approach to their analysis and thus the properties of the material. As these thermal properties will change with temperature Material Modeler has, and is continuing to develop modeling of these thermal properties with respect to temperature to support the growing segment of thermal-mechanical simulation and analysis.
