Shear Viscosity
Once the file is imported and the viscosity data is fit, the Cross Model with Williams -Landel-Ferry (WLF) is displayed as the default viscosity model pair. To inspect other options, choose a model for shear viscosity or temperature dependence to review the Viscosity vs Shear Rate and Temperature.
- Select the Shear Viscosity Constituent Model or the Temperature Dependence of Eta0(T) (i.e. η0(T)).
- Edit the field values to improve the quality if necessary.
Click to save the changes to the model values.
- Click Approve Model Fit to approve the viscosity fit and move to the Recommended Process Conditions tab. Default values are populated into the fields there based on the material family. Change these values if more specific information is available (i.e. in a lab test report).
