A one element model in tension used as a test model and compare with analytical
results.
The Yeoh model can be used to describe nearly impressible hyperelastic materials,
like rubber. Set Yeoh parameter with LAW94 and compare one element tension Radioss results with analytical results.
Options and Keywords Used
/MAT/LAW94 (YEOH)
Input Files
Before you begin, copy the file(s) used in this problem
to your working directory.
Uniaxial tensile one brick element with imposed displacement and fixed in other side
only in X direction.
Units: mm, s, Mg, N, MPa
Properties: /PROP/SOLID with, Isolid=24, Ismstr=10, and Icpre=1
Note: When using hyperelastic material laws, there are some recommended element property
settings. When using solid elements, it is always better to mesh with 8 node
/BRICK elements, if possible. If not, then
/TETRA4 or /TETRA10 elements can be used.
Recommended /PROP/SOLID for 8 nodes brick are, Isolid=10, Icpre=1, with Isolid=24. If hourglassing occurs, then Isolid=18 can be used.
Simulation Iterations
Yeoh theory:
The Yeoh energy density is: (1)
This example assumes an incompressible () hyperelastic material, then the strain
energy density of Yeoh simplified, as: (2)
With (3)
Where,
Deviatoric stretch with and .
The stretch in principal direction 1, 2, 3.
Engineer strain in principal direction I.
It shows only three parameters need to be defined for the
(incompressible) Yeoh model.
Uniaxial test is used in this
example, then:
and
The Cauchy stress of Yeoh model is
computed as: (4)
In the uniaxial test, the Cauchy stress (true
stress) in principal direction 1 is: (5)
The engineer stress is:(6)
In this example, three material parameters are
defined below: (7)
LAW94:
The hyperelastic model uses polynomial model and the Yeoh
model is one of the polynomial model with only three parameters. In this
example, viscous was not considered.
Results
In LAW94 Yeoh model, three parameters
defined same as analytical case.
D1 needs to be defined in the material card. If D1 is not defined in LAW94, then the
default Poisson’s ratio 0.495 is used.
Then 1/D1=17.94 is printed in the Starter output file.
Compare the above results, then show the difference with analytical results
especially in high deformed area.
In order to match the incompressible hyperelastic analytical results, the Poisson’s
ratio needs to be defined as close to 0.5 as possible, but can not be simply defined
as , which will lead to infinite small time step in
numerical computation. In this example is used. It shows Radioss results are well matched with analytical results.
Since material incompressible is assumed in analytical calculation., Poisson’s ratio
closer to 0.5 is better, but the computation time will increase. Just one element
tension model from to run time is more than 20 times increased. In this
example, use ; therefore, set D1=0.003334.
