Starter Subroutine LECSEN_USRn
This subroutine read the user’s sensor input data. The number of cards and their formats are free.
Arguments
The argument list of LECSEN_USRn and its individual arguments and descriptions
are:
C-------------------------------------------------------------------------
SUBROUTINE LECSEN_USRn(IIN, IOUT)
Definition
| Argument | Format | Description |
| IIN | Integer read only scalar | Input file unit (Starter input file) on which the data are read. |
| IOUT | Integer read only scalar | Output file unit (Starter output file). |
Storage Functions for Sensor Parameters (Starter Only)
To store data in a sensor’s parameters buffers, use:
integer ierr = SET_U_SENS_IPAR(integer isens, integer sens_index, integer var)integer ierr = SET_U_SENS_FPAR(integer isens, integer sens_index, float var)
These functions store an integer or float variable in respective buffers, at a
position indicated by sens_index, which is independent in each
buffer. The length of sensor parameter buffers is limited to 12 integer variables
and 20 float variables.
