/IMPL/NONLIN/N
Engine Keyword Nonlinear implicit methods.
/IMPL/NONLIN/N
L_A Itol Toli Tolj Tolk
Definition
| N | Nonlinear solver method.
| L_A | Maximum iteration
number of stiffness matrix updates.
| Itol | Termination criteria.
| Toli ... Tolj ... Tolk | When
(Itol = 1,
2, 3), tolerance for
termination. Toli
When (Itol = 12, 13, 23) two tolerances for termination. Toli
Tolj
When (Itol = 123) three tolerances for termination. Toli
Tolj
Tolk
- For static implicit computation, the loading should be defined as monotonous, increasing time function to better manage the convergence.
- Order of input tolerance is
according to the Itol value with 1: energy;
2: force; and 3: displacement.
Example: Itol = 23, the order is Tolerance in force and Tolerance in displacement.
