/IMPL/NONLIN/SOLVINFO
Engine Keyword Output global solve information at each solving iteration.
This command creates three additional files:
- Filename_implicit.info: for largest residuals (force and moment), largest displacement and rotation increments and largest corrections at each iteration and each increment.
- Filename_implicit.hist: contains all data for plotting purposes in Altair HyperWorks.
- Filename_implicit.tpl: a tpl script for plotting in Altair HyperWorks the data from .hist file
- If the run is launched
from Compute Console (ACC), a plot of residuals, displacements Can be displayed
and updated during solve. To do this:
- Launch Radioss from the Compute Console (ACC)
- Click the Graph button to plot the desired graph.
- To plot the solve
information at the end of the run:
- Launch HyperMesh post-processor
- Load the generated .tpl file (), different graphs are then plotted (Fig. 2)
Figure 1. Solvinfo plots in HyperMesh
