/DEL/PART/1
Engine Keyword Delete part numbers N1first to N1last, …, NIfirst to NIlast.
/DEL/PART/1
N1first N1last ... NIfirst NIlast
Definition
Data Description SI Unit Example
N1first … N1last First and last element number of a range to delete.
Maximum 100 characters per line.
  1. The part numbers can be listed in multiple lines with a maximum of 100 characters per line.
  2. The part numbers can be separated by a comma or a space.
  3. Parts with void material cannot be deleted.
