/DEL
Engine Keyword Delete element numbers N1, N2, . . ., NN.
/DEL/Eltyp
N1, N2 . . ., NN
NN+1, NN+2 ..., NM
Definition
Eltyp Element type:
BRICK
Brick elements
QUAD
Quad elements
SHELL
Shell elements
SH_3N
Triangular shell elements
SPHCEL
SPH elements
TRUSS
Truss elements
BEAM
Beam elements
SPRING
Spring elements
N1, N2, . . ., NN List of element numbers.
Maximum 100 characters per line.
  1. The element numbers can be listed in multiple lines with a maximum of 100 characters per line.
  2. The element numbers can be separated by a comma or space.
  3. Elements with void material cannot be deleted.
