/INTER
Engine Keyword Describes an interface.
/INTER
inter_ID Nsearch Tstart Tstop
Definition
| inter_ID | Interface identifier. | |
| Nsearch | Search of closest node
every Nsearch
cycle. Default = 10 |
| Tstart | Start time. | |
| Tstop | Stop time. Default = 1030 |
- An interface can be activated and deactivated using Tstart and Tstop.
- Only one single interface can be defined in a card.
- Nsearch is deprecated and no longer used, any value can be set.
