OS-E: 5000 Conjugate Heat Transfer Analysis (TFSI) of Inline-4 Engine Head with OptiStruct and AcuSolve
The Conjugate Heat Transfer Analysis of a cylinder head to evaluate temperatures in the engine block by taking into account the coupling effect with the fluid domain.
Figure 1. FE Model
Model Files
Model Description
- FE Model
- Element Types
- CHEXA
- MAT1
- Young’s Modulus
- 21500 MPa
- Poisson Ratio
- 0.3
Results
Figure 2. Temperature Contour
Figure 3. Pressure Contour on the Fluid Domain
