Altair HyperWorks Licensing 2023 Release Notes
New Features
Product License Features
The following Altair HyperWorks applications and tools are available under Altair Units (AUs) licensing:
EEvision
EEvision interactively renders up-to-date schematics for targeted electrical components, connectivity, and influence to simplify the electrical system development and maintenance. It contains the following products and add-ons:
EEvision Basic
An online visualization platform for schematics of circuits, wiring harnesses, and components. This product requires 40 AUs (units are stacked against other Altair products).
EEvision Pro
Basic edition, plus some additional plug-ins (module navigator, module editor, shield and twist visualization, and end-circuit visualization). This product requires 55 AUs (units are stacked).
EEvision DocGen Add-on
An add-on for automatic document generation. This product requires 50 AUs (units are stacked).
EEvision Diff Add-on
A comparison tool for two EDB models. This product requires 50 AUs (units are stacked).
EEvision SignOff Add-on
An add-on for team sign-off capability. This product requires 50 AUs (units are stacked).
StarVision PRO
A debug solution for advanced electronic SoC (Silicon-on-Chip). This solution requires 50 AUs (units are stacked). The table below lists additional features and the units required:
Feature Description Units Required
StarVisionPro Debug solutions for advanced electronic SoC (Silicon-on-Chip); units are stacked. 50
SpiceParser Spice parser; units are leveled. 10
RTLParser RTL parser; units are leveled. 10
NetlistParser Netlist parser; units are leveled. 10
SV_Skill_Export Skill export; units are stacked. 20
SV_WaveForm_Analog Analog waveform viewer; units are stacked. 10
SV_Parasitic Parasitic analysis package; units are stacked. 10
SpiceVision Pro
Creates schematics, circuit fragments, and design documentation from Spice netlists. The table below lists additional features and the units required:
SpiceVisionPro Creates schematics, circuit fragments, and design documentation from Spice netlists; units are stacked. 20
GateVision PRO
Graphical gate-level netlist analyzer. The table below lists additional features and the units required:
GateVisionPro Graphical gate-level netlist analyzer; units are stacked. 20
RTLvision PRO
Visualization of large RTL designs, including third-party IP and reused blocks. The table below lists additional features and the units required:
RTLvisionPro Visualization of large RTL designs, including third-party IP and reused blocks; units are stacked. 25
RTLparser RTL parser; units are leveled. 10
HyperMesh CFD
A solution centric streamlined user interface which provides end-to-end workflows for aerodynamics, aeroacoustics, internal flow, multiphase flow, thermal and moving mesh simulations.
HyperMeshCFD A solution centric streamlined user interface which provides end-to-end workflows for aerodynamics, aeroacoustics, internal flow, multiphase flow, thermal and moving mesh simulations. 21
Inspire
Four features are introduced to Inspire 2023 as following:
InspireGeometry Enable the Geometry capabilities in Inspire. 15
InspirePrint3D Set up model for Print3D. 15
InspireSimSolid Use SimSolid as structural analysis solver. 30
InspireFluidsSolver Integrates easy-to-use CFD exploration tools in the Inspire simulation driven design process. 30
InspireFluids Integrates easy-to-use CFD exploration tools in the Inspire simulation driven design process. 30
Inspire Form
A new feature, InspireRadiossSolver, is introduced in v2023 to replace InspireFormIncrSolver license feature. This feature is required to nvoke Tryout GUI and run incremental analysis using Radioss solver. This product requires 30 AUs.
Inspire Extrude
A license feature, InspireOSSolver, is added. It is required when OptiStruct is used for structural analysis. This product requires 15 AUs.
Inspire Mold
Flux
A new feature, Flux2DSolver, is introduced to support Flux2D analysis. 15 units are required when running Flux2D solver for one core. Multi-core usage follows the Solver In-App Licensing table.
FluxMotor
A new feature, FluxMotorFlux2DSolver, is introduced to support Flux2D analysis in Flux Motor. 15 units are required when running Flux2D solver via FluxMotor for one core. Multi-core usage follows the Solver In-App Licensing table. The FluxMotor GUI interface now requires 21 AUs.
Altair License Manager
Altair HyperWorks 2023 products require the Altair License Manager 15.2 or the latest version. The License Manager is compatible with previous versions of Altair software.
Note: Altair HyperWorks products that have upgraded the ALSDK to v15.1 no longer work with Altair License Manager 14.5.1 or older.
For more information, reference the Altair Units Licensing section in the Altair HyperWorks documentation.
Enhancements
Updates to Existing License Feature Names
Several product license feature names have been updated. See details in the Altair Units Licensing section of the Altair HyperWorks documentation.
