Green House Noise - Result Visualization Tab
The Results Visualization tab contains two sections: Interior Noise Levels Plotting and dBMaps Visualization.
Interior Noise Level Plotting
From this section, select the microphone location and type of output required, like source and panel type contribution.
Click Display Options to customize the output.
Click Export Data to export the contribution data to a file. Use a right-click context menu to convert an interior noise curve to an audio file.
Figure 3.
Figure 4.
dBMap Visualization
From this section, you can visualize the acoustic and hydrodynamic dBMap of the panel selected during the result generation.
Additionally, choose the band type and frequency band for the dBMap.
Figure 5. Hydrodynamic dBMap
Figure 6. Acoustic dBMap
