Design Sensitivity - Load
Perform file and result selection.
File selection
Select an OptiStruct dsa.0.h3d file that contains proper design sensitivity output. Upon reading the file, the Result selection fields are populated.
Result selection
The following fields are available under Result selection. Once the result selection options are complete, click Load Response to further investigate the sensitivities.
Subcase
Select an analysis subcase from the drop-down menu.
Result type
Only one result type is available: Design Sensitivity
Result ID
The grid ID of the response for which design sensitivity results are available. Select one from the drop-down menu.
Response label (optional)
Enter a label that describes the response, for example, Driver’s Ear.
Direction component
X, Y, or Z.
Design response set
A design response set is displayed.
Display Options
Use the Display Options dialog to customize the response plot, including scale, weighting, and the plot layout.
Load Response
Once the result selection options are complete, click Load Response to display the file data.
