Multiple Sample Analysis, Loads MSA - Display
Plot responses for runs with highest and lowest responses for a particular frequency or a range of frequency.
It is also possible to review the randomized values used for the variables in a particular run. From the Parameter Effects tab, plot sensitive parameters contributing to response scatter at a particular frequency. Before using this tab, you must first load a file from in the Load tab.
- Run Info
 - Allows you to visualize responses for highest and lowest responses. Also
                            allows review of parameter values used in specific run.
- Speed Selection
 - Select an option to choose specific speed or speed range.
 - Specific Speed
 - Enter a specific speed or use the slide bar to select a frequency value.
 - Speed Range
 - Speed range indicates the available range, based on your result PCH file. Using the From and To fields, you can customize your own frequency band.
 - Show Highest, Lowest and Nominal
 - See the runs with highest, lowest and nominal runs.
 - Show highest runs
 - Select the number for which the you want to see the runs with highest responses.
 - Show lowest runs
 - Select the number for which the you want to see the runs with lowest responses.
 - Display Options
 - The Display Options dialog allows you to customize the plot, including scale, weighting, and the plot layout.
 - Display
 - Click Display to display the response plots, for chosen number of highest/lowest runs.
 - Run Directory
 - Select the directory with Multiple Sample Analysis runs.
 - Run Number
 - Click the response curve and the corresponding run number is listed. It is also possible to enter the run number manually.
 - Contributors
 - Review of randomized parameter value used in selected HyperStudy run.
