View an ID List for Set Entities
Set entities are used to define and store lists of entity IDs for a specific entity.
Sets can be generated for nodes, elements, components, assemblies, properties, and materials, which contain entity IDs for that specific entity. In the Entity Editor, you can view an ID list for set entities. The entity IDs are compacted using ranges, and segregated using ID pools. If some of the IDs are unresolved, than they will be listed separately under Unresolved IDs.
                Right-click on the Entity IDs field, or click
, then select ID List from the context menu.
             - In the ID List dialog, review a list of all of the entity IDs.
 - When you are finished, click Close.
