Create and Edit Assigned Entities
Create, edit, and assign new entities to an existing entity or group of entities in the Entity Editor.
Create and Assign a New Entity
To create and assign a new entity to an existing entity or a group of entities:
                Right-click on an entity assignment field, or click
, then select one of the following options
                    from the context menu:
- Create - Define a new entity using an embedded Entity Editor.
 - Create/Edit - Define a new entity using a standalone Entity Editor. Available only when the embedded Entity Editor is not supported.
The Entity Editor creates and assigns the new
                        entity.
            Edit an Assigned Entity
To edit an entity that is assigned to an existing entity or a group of entities, do one of the following:
                Click
 next to an entity assignment field. In the
                    embedded Entity Editor, modify the entity data. When you
                    are finished making changes, click
 to collapse the
                    editor.
, then select Edit
                    from the context menu.
                - Modify the entity data using the embedded Entity Editor.
 - Modify the entity data using the standalone Entity Editor, Available only when the embedded Entity Editor is not supported.
Create and Assign Sets to Main or Secondary Entities
                Right-click on the Secondary Entity IDs or
                        Main Entity IDs fields,
                        or click
, then select Create Set using
                        Elements, Create Set using Nodes or
                        Create Set using Segments from the context menu.
                Note: The options available depend on the solver keyword selected. - Use the corresponding entity selector to pick elements, nodes, or segments.
Select Set Segments
The following additional functionalities are available in the entity selector when editing the contents of a set segment.
- Use standard selection controls to append or deselect elements, facets, faces, or edges where the segments are defined.
 - Click
 to reverse or align segment
                    directions using the Adjust Directions dialog. The reverse
                    function flips all or some segment directions simultaneously. The align function
                    is only available for segments defined on shell elements.Tip: When aligning segments on shell elements, you can manually specify a reference element to align to by toggling the switch from Auto to Reference mode. - When selecting 3D elements, segments are added to their outside faces only,
                    based on the current display state.Tip: While selecting set segment contents, you can freely switch between supported selection types (for example: elements, facets, faces) and the current selections are converted accordingly.
The following restrictions and considerations apply when selecting set segment contents:
- A single set segment can contain either face (2D) segments, or edge (1D)
                        segments, but not a mixture of both.
- When using box selection, if a mixture of 1D/2D elements is detected, the 2D elements are given priority. Only the 2D elements inside the box are selected and any 1D elements are ignored.
 - Switching the selection type between elements, faces, and facets is
                        supported, but some conversions might result in additional segments.
- Example 1: A single facet of a single floating 3D hex element is currently selected, and the selector is then switched from facets to elements. The selection is converted correctly from 1 facet → 1 element, and upon accepting the new selection, the resulting number of segments is now 6 since every exposed side of the selected 3D element gets a segment.
 - Example 2: If the same 3D element is not floating but instead part of a displayed mesh, the resulting number of segments is less than 6 because only its currently exposed outside faces get a segment (hidden internal mesh faces do not get segments).
 - When selecting faces or facets, advanced selection operations are available (for example: select adjacent, reverse, by face, by path, and so on) which rely on their underlying elements. As such, any advanced selection operation performed on faces or facets considers their current base elements as fully selected (including all outside faces of 3D elements). The same applies to saving and retrieving selections via the right-click menu.
 - When selecting facets, performing graphical window selections of a large number of facets can have a significant performance cost. For such scenarios, using elements as the selection type is recommended for optimal performance.
