2026
Discover HyperLife Weld Certification functionality with interactive tutorials.
View new features for HyperLife Weld Certification 2026.
Learn how to access and download required model files.
Tutorial Level: Beginner This tutorial guides you through a step-by-step process that covers all the major functionalities of HL-WC. By working through the tutorial, you can quickly learn the tool and start using HL-WC to evaluate the welded connections in your FE models using standard weld evaluation methods.
Tutorial Level: Beginner This tutorial guides you through a step-by-step process that covers the certification of both welds and unwelded material in the same calculation.
Set up the model for weld evaluation.
Learn details about the core modules used in HL-WC calculations along with the parameters that are assigned based on the standards.
Learn how to manipulate entities.
