Save Files
Save all of the data in your current session.
                Do one of the following:
- From the Home tools, Files tool group, click the Save As tool.Figure 1.
- Select a save option from the File menu.
- Click to save a *.hm file.
- Click to save a *.hlf file.
- Press Ctrl + S to save a *.hm file or Ctrl + Shift + S to save as.
On Linux, the directory is /usr/tmp/Fatigue/RunHistory/
You can change the directory from the Preferences dialog.
