Open Files
Open a file.
The directory where file dialogs are opened is saved from the previous successful
                dialog operation. For example, if you select a file in
                    C:\my_files, the next time a file dialog is opened, it will
                open in C:\my_files. There are a few exceptions:
        - If the dialog is associated to a filename entry box, the directory is taken from the path entered in the entry box, instead of using the saved directory.
- Certain dialogs take you to a directory in the installation where the selection would commonly be made, instead of using the saved directory.
- If the directory is not valid, the file dialog opens in the application start-in directory.
                Open a file one of the following ways:
                - From the Home tools, Files tool group, click the Open Model tool.Figure 1.
- From the menu bar, select .
- In the Open Model/Results Files dialog, browse for and select an *.hm model file and a respective result file (*.op2, *.h3d) to support the fatigue calculation.
- Click Apply.
Tip: To open recently used files, click
                    File from the menu bar and select
                an option from the Recent Files list.
        Click  to pin a file
                    to the list.
 to pin a file
                    to the list.
