User Interface
Explore the user interface.
RibbonsResults BrowserEntity EditorEntity SelectorModeling WindowAdjust the ViewStatus BarAnimate Models
  1. Menu Bar
    The menu bar contains pull-down menus that provide access to standard functions such as file management operations, system preferences, and help.
  2. Ribbons
    The ribbon allows you to quickly access tools and standard functions, and is located along the top of the user interface. Click on an icon to open the related tool. Hovering over a group of icons may reveal additional tools.
  3. Results Browser
    The Results Browser allows you to view the model structure while providing find, display, and editing control of entities.
  4. Entity Editor
    Use the Entity Editor section of the Results Browser to view and edit various entity conditions/properties.
  5. Entity Selector
    Use the entity selector to specify which type of entity you are able to select.
  6. Modeling Window
    The modeling window is where your model is displayed.
  7. View Controls
    View controls enable you to control the view and display of your model in the modeling window.
  8. Status Bar
    The status bar displays information pertaining to the currently loaded model.
  9. Animation Toolbar
    View your model in motion using animation controls.
