Standalone Applications Unit Draw
In addition to the applications listed above, there are several standalone applications that draw Altair Units. The following table is a summary of AUs drawn of those applications.
Product | AUs | License Feature | Description |
EDEM BulkSim | 21 | EDEMBulkSimGUI | BulkSim GUI application. |
40 | EDEMBulkSimSolver | In CPU mode, using up to 12 cores it should be a constant draw of 40 AUs. | |
60 | EDEMBulkSimSolver | In GPU mode, it should pull the equivalent of 16 cores and draw 60 AUs. Stacking on the second plus. | |
EEvision Basic | 40 | EEVisionBasic | Online visualization platform for schematics of circuits, wiring harnesses, and components. AUs are stacked. |
EEvision Pro | 55 | EEVisionPro | Basic edition plus some additional plug-ins (module navigator, module editor, shield and twist visualization, endcircuit visualization). AUs are stacked. |
EEvision DocGen Add-on | 50 | EEvisionDocGen | Automatic document generation. AUs are stacked. |
EEvision Diff Add-on | 50 | EEvisionDiff | Comparison tool for two EDB models. AUs are stacked. |
EEvision SignOff Add-on | 50 | EEvisionSignOff | Team sign-off capability. AUs are stacked. |
Embed OpenVision | No | No | Add-on for Embed. |
Embed Viewer | No | No | Read-only version of Embed. |
Embed Basic | 1 | EmbedBasic | Same as EMBED with a 100 block limit. |
Embed eDrives | 4 | EmbedeDrives | A comprehensive set of motor control blocks covering AC Induction, BLDC, brushed, PMSM, and stepper motors for simulation, code generation, and HIL. |
Embed Digital Power Designer | 10 | EmbedDigitalPower | Used for the design and development of digital power supplies and power conversion equipment. DPD is an Add-on for Embed. |
Embed Simulation Edition | 10 | EmbedSimulation | Also known as EmbedSE, is a block diagram and state chart environment for modeling, simulation, analysis, and control system development. In addition to its simulation capabilities, it also supports real time data monitoring and control using National Instruments and other boards as well as OPC, CAN, UDP, Serial, and MQTT. |
Embed | 21 | EmbedCodeGen | Also called Embed Professional, is an extension of EMBED Simulation Edition for model-based firmware development supporting all microcontrollers, and with enhanced support for the following: Arduino®, ARM®-Linux® (Raspberry Pi™, AMD64, NVJetson/Nano), STMicroelectronics®, and Texas Instruments™. |
ESAComp | 6 | ESAComp | Composite design software. AUs are stacked. |
Flow Simulator | 50 | FSimGUI, FSimSolver |
Integrated flow, heat transfer, and combustion design software that enables mixed fidelity simulations to optimize machine and systems design. GUI levels. First solver instance levels, second plus stacks. |
HyperSpice | 50 | HyperSpice | Altair HyperSpice is an analog
electronic circuit simulator. It features a command line tool
reading input text files written in Spice syntax and a waveform
viewer. Standalone SPICE circuit solver requires 50 AUs. AUs are stacked. See Solver section. |
30 | HyperSpiceBasic | Basic standalone SPICE circuit solver has limit in number of circuit nodes First solver instance levels, second plus stacks. See Solver section. | |
6 | HyperSpiceViewer | Spice waveform viewer requires 6 AUs. AUs are leveled. | |
Material Modeler | 35 | MaterialModeler | A material modeling software that allows you to quickly and accurately process raw test material data and generate required inputs for simulation-ready material cards for the nonlinear behavior of bulk materials like metals and plastics. |
PollEx Logic/CAM | No | PollExEntity | Logic, CAM, BOM |
PollEx PCB Modeler | 10 | PollExBasic | PCB Modeler (PCB, Real PCB Assembly Viewer, Cross Probe (CP), UPE (Unified Part Editor)) |
PollEx PCB Verification | 30 | PollExVerification | PCB Design for Manufacturing (DFM), Design for Assembly (DFA), Design for Electrical (DFE), Design for Electrical Plus (DFE+), Logic DFE. |
PollEx PCB Verification Post-Processing | 21 | PollExPostVerification | PCB Design for Manufacturing (DFM), Design for Assembly (DFA), Design for Electrical (DFE), Design for Electrical Plus (DFE+), Logic DFE – Result visualization. |
PollEx PCB Solver | 30 | PollExSolver | PCB Solvers for signal integrity, power integrity, thermal analysis. |
PollEx MFG | 30 | PollExMFG | PollEx Manufacturing options |
PollEx UDE | Feature-based server | PollExUDEServer | Feature-based license server with a fixed annual per socket up to 50 users. |
4 | PollExUDEUser | Additional checkout for each client access draws 4 AUs. | |
PSIM Power Supply | 10 | PSIMPowerSupply | PSIM is a Power Electronics simulation environment with digital and analog control, thermal loss models, battery, and photovoltaic models. Also includes Design Suites for Power Supply and EMI. |
PSIM Code Generation | 15 | PSIMCodeGen | PSIM embedded code generation and target support for TI C2000 MCUs. |
PSIM Interface | 15 | PSIMInterface | PSIM co-simulation interfaces with Simulink, JMAG, Modelsim, Twin Activate, Embed, and FMI. |
PSIM Motor Drive | 20 | PSIMMotorDrive | Includes functionality of Power Supply along with PSIM machine and mechanical load models. Includes Design Suites for Motor Control and HEV. |
Pulse | 30 | Pulse | Orchestrates meaningful models from the broad workflows required to simulate complex systems of systems to the focused workflows needed to enable fast, reliable, and repeatable modeling, analysis, and optimization. |
S-CONCRETE | 10 | SconcretePro, Sline, SconcreteEtabs | Design and detail sections of reinforced concrete beams, columns, and walls or continuous concrete beams to meet regional design code requirements and generate customizable design reports. Includes S-CONCRETE and S-LINE. |
S-FRAME | 10 | SframePro, SsteelPro, Spad, Icd, Sview, Scalc, SframeEnt, SsteelEnt | Structural analysis with integrated steel and concrete design solutions enabling structural engineers to model and perform linear or advanced non-linear analysis. Design steel and concrete members to meet regional code requirements, generate design reports, and calculate advanced section properties for non-standard sections. Includes S-FRAME Analysis, S-STEEL, S-PAD, ICD, and S-CALC. |
Structural Office | 10 | StimberPro, StimberCSA, StimberNDS, SfoundationPro, SfoundationACI, SfoundationCSA, SfoundationEURO, Scalc, StimberEnt, StimberAISC, StimberCSAS16, SfoundationEnt | Hybrid timber structural analysis with integrated mass timber and foundation design solutions enabling structural engineers to simulate hybrid timber structures constructed from mass timber, steel, and concrete. Design mass timber members and concrete foundations to regional design code requirements, generate design reports, and calculate advanced section properties for non-standard sections. Includes S-TIMBER, S-FOUNDATION, and S-CALC. |
StarVision PRO | 50 | StarVisionPro | Debug solutions for advanced electronic SoC (System-on-chip). AUs are leveled. |
10 | SpiceParser | Spice parser. AUs are leveled. | |
10 | RTLParser | RTL parser. AUs are leveled. | |
10 | NetlistParser | Netlist parser. AUs are leveled. | |
20 | SV_Skill_Export | Skill export. AUs are stacked. | |
10 | SV_WaveForm_Analog | Analog waveform viewer. AUs are leveled. | |
10 | SV_Parasitic | Parasitic analysis package. AUs are leveled. | |
SpiceVision PRO | 20 | SpiceVisionPro | Creates schematics, circuit fragments and design documentation from Spice netlists. AUs are leveled. |
10 | SV_Parasitic | Parasitic analysis package. AUs are stacked. | |
GateVision PRO | 20 | GateVisionPro | Graphical gate-level netlist analyzer. AUs are leveled. |
RTLvision PRO | 25 | RTLvisionPro | Visualization of large RTL designs including third-party IP and reused blocks. AUs are leveled. |
10 | RTLparser | RTL parser. AUs are leveled. | |
OmniV | 15 | MBSE_omniV | OmniV empowers open model-based systems engineering (MBSE) practice across systems, simulation, test, product development, and controls engineering by formalizing the development, integration, and use of models to inform enterprise and program decision-making. |
FlightStream | 50 for up to 4 cores, see table | FlightStream | A surface-vorticity, viscous-coupled panel solver for rapid aerodynamic simulation. Capable of modeling incompressible through hypersonic flows. Use 50 AUs up to 4 cores. Additional units are required for more cores, following the OptiStruct in App unit draws. |
