Platform Support
Platforms, operating systems, and processors supported by Altair HyperWorks 2025 products, which includes 2025 solver packages.
Platforms | Altair HyperWorks 2025 | |||
OS | Version | Architecture | GUI Products | Solvers |
Windows | 10 | x86_64 | YES | YES |
Windows | 11 | x86_64 | YES | YES |
Linux | RHEL / CIQ Rocky Linux 9.4 | x86_64 | YES | YES |
- Windows Ultra High Definition (UHD/HiDPI) support requires Windows 10 Update 1709 or higher
- RHEL= Red Hat Enterprise Linux
- Linux
- Altair HyperWorks products may install and run on other non-supported Linux distributions not mentioned or referred to in this documentation, but Altair does not test, certify, verify or warrant the reliability of the products on these platforms.
- Ultra High Definition (UHD)
- UHD resolution support (2160p) is only available for Windows 10
(1709 or higher).
- Using Windows 200% scaling for 2160p is recommended.
- Our recommended HD setting is 1080p for FHD and our Ultra HD setting is 2160p.
- Java based tools within our products may still show some scaling issues under Ultra HD resolution.
(1709 or higher).
Refer to the Hardware Recommendations and Certifications section for details.
Altair HyperWorks Products
- Altair® HyperMesh®
- Altair® HyperView®
- Altair® HyperGraph®
- Altair® MotionView®
- BatchMesher
- Altair® HyperLife®
- Altair® HyperMesh® CFD
- Altair® HyperMesh ® NVH
- Altair® HyperStudy®
- Altair® HyperView Player®
- Altair® SimLab®
- Altair SimSolid® (Windows only)
- Altair® Feko®
- Altair® Feko® Applications
- Altair® newFASANT™
- Altair® WinProp™
- Altair® Flux®
- Altair® Solvers™
- Altair® OptiStruct®
- Altair® Radioss®
- Altair® MotionSolve®
- Altair® HyperXtrude®
- Altair® Manufacturing Solver™
- Altair® Multiscale Designer®
- Altair® Seam®
- Altair® HyperLife® Solver
- Altair® CFD Solvers™
- Altair® AcuSolve®
- Altair® ultraFluidX® (Linux only)
- Altair® nanoFluidX®
- Altair® Twin Activate®
- Altair® Compose®
- Altair® EDEM™
- Altair® Inspire™
- Altair® Inspire Cast™ (Windows only)
- Altair® Inspire Extrude™ (Windows only)
- Altair® Inspire™ Extrude Metal
- Altair® Inspire™ Extrude Polymer
- Altair® Inspire™ Friction Stir Welding
- Altair® Inspire™ Resin Transfer Molding
- Altair® Inspire Form™ (Windows only)
- Altair® Inspire™ Mold (Windows only)
- Altair® Inspire™ PolyFoam (Windows only)
Platforms Added in Altair HyperWorks 2025
- RHEL / CIQ Rocky Linux 9.4
Platforms Dropped in Altair HyperWorks 2025
- SLES 15 SP3
- RHEL 8.4
Minimum Operating System Requirements
System/Hardware Information | Linux | Windows | ||
Operating Systems |
RHEL 9.4 (64-bit) CIQ Rocky Linux (64-bit) |
10
(64-bit) 11 (64-bit) |
CPU | AVX2 support | AVX2 support | ||
Memory | 16 GB (higher recommended) | 16 GB (higher recommended) | ||
Complete Install Disk Space ~8 GB temporary disk space required for full Altair HyperWorks 2025 installation |
Applications 72 GB |
Help 12 GB |
Applications 110 GB |
Help 12 GB |
Graphics Hardware 2 | OpenGL 3D graphics accelerator
compatible with OpenGL 3.3 or higher Vulkan 1.2 or higher OpenCL 2.1 required True color (24-bit) support Install/update to most recent OpenGL patches/drivers 1920x1080 screen resolution or higher for optimal user experience 4 GB or higher dedicated RAM Only dedicated NVIDIA GPUs are supported (AMD, Intel® Arc™, and integrated onboard Intel chipsets are not supported) |
compatible with OpenGL 3.3 or higher Vulkan 1.2 or higher OpenCL 2.1 required True color (24-bit) support Install/update to most recent OpenGL patches/drivers 1920x1080 screen resolution or higher for optimal user experience 4 GB or higher dedicated RAM Only dedicated AMD, Intel® Arc™, and NVIDIA GPUs are supported (integrated onboard Intel chipsets are not supported) |
Linux System Requirements
Run the HyperWorks compatibility tool to validate your Linux compatibility with Altair HyperWorks products located under the <INSTALL_PATH>/altair/hwdesktop/utility/HWCompatibilityTool/ folder.
