Get Updates and System Information
In addition to the main releases of Altair HyperWorks products, Altair issues software updates between major releases.
To get information about the latest updates and the base installation directory, use
the HyperWorks Updates and System Information dialog. The
Updates Information tab displays information about the current release of the
application including installed updates and the versions of major application
executables. The System Information tab displays the information about the machine
type, hardware, operating system, graphic card, and user name.
Attention: On Windows 11, WMIC is now an optional
feature. If WMIC is not installed, the System Information
tab will not work properly and will instead display an Application Error
message.
- To access the HyperWorks Updates and System Information dialog, from the File menu, click .
- To view the release notes for the installed products, click the links in the Updates Information tab.
- Use the Copy button to fill the clipboard with the update information. This information may then be pasted into email when corresponding with Altair Support.
