Induction machines – Motor Factory – Test environment
Run the basic test twice consecutively can lead to wrong results.
When you run the test Characterization / Model /Basic twice consecutively by only changing the line-line voltage, the results you get at the end of the second run are wrong.
Indeed, in that case, you will see that the line-line voltage is inconsistent with the phase voltage meaning that our internal process considers that the voltage has not been modified especially for computing the no-load performance leading to wrong results for the equivalent scheme parameters (ref.: FXM-16302).
This issue has been corrected.
Computation of working point using the accurate mode is not possible for slips higher or equal to 1.
The internal process is not compatible with such values of slip (ref.: FXM-16163).
