All machines
Negative end winding resistance with low value of X-Factors.
Here are a few explanations for this issue:
With X-factor=1, we have (Rphase 0)=(Rstraight 0)+(R end winding 0)
Rphase 0 is the initial value of the phase resistance (with X-Factor = 1)
RStraight 0 is the initial value of the phase resistance in the straight part of the machine (with X-Factor = 1)
R end winding 0 is the initial value of the phase resistance in the straight part of the machine (with X-Factor = 1)
With X-factor≠1, we have (Rphase 1)=(Rstraight 1)+(R end winding 1)
Rphase 1 is the initial value of the phase resistance (with X-Factor ≠1)
RStraight 1 is the initial value of the phase resistance in the straight part of the machine (with X-Factor ≠1)
R end winding 1 is the initial value of the phase resistance in the straight part of the machine (with X-Factor ≠1)
The target is to get the following results:
(Rphase 1)=XFactor×(Rstraight 0)
With
(Rstraight 1)= (Rstraight 0)
This leads to the value for the end winding resistance:
(R end winding 1)=XFactor×(Rstraight 0+R end winding 0)-(Rstraight 0)
(R end winding 1)=Rstraight 0×(XFactor-1)+XFactor×(R end winding 0)
When X-Factor is very low, the end winding resistance can be negative.
This issue has been corrected.
Trouble with Script - Export script - Export python - Export python in ScriptFactory
Removing selected folders in which are stored python files leads to troubles while suing the “Search directory function” (ref.: FXM-16164).
Hairpin architecture
Solving tests or exporting projects to Flux is not allowed when the Hairpin winding is built with two layers. This will be fixed for the next version (ref.: FXM-15516).
Excel export does not work for the test Model - Maps
For the Synchronous machines with Permanent Magnets – SMPM (ref.: FXM-15465).
