Impedance computation - Cst
Overview
The aim of this section is to compute the inter bar and inter pole impedance of the damper circuit end rings.
| END RING - IMPEDANCE area | |
| 1 | Shortcut panels to navigate in the impedance results |
| 2 | Main window for visualizing the machine axial view |
| 3 | Section dedicated to inter bar and inter pole impedance definition |
| 4 | “Automatic” computation mode selection |
| 5 | Constant computation mode |
| 6 | Icon to export end ring impedance data into *.txt or *.xlsx files. |
When constant computation mode is set, the inter-bar and inter pole end-ring resistance and inductance values must be set by the user. The values are given for a reference temperature. In this case the inter bar end ring resistances and inductances are always a function of temperature (function depending on the material of the end-ring). Once again, the inter bar impedance can only take an average value, even if bars are not evenly distributed.
| END RING – Constant computation mode | |
| 1 | “Constant” computation mode selection |
| 2 | Impedance characteristic to be defined |
