DC PM IR
Direct Current Permanent Magnet Machine
The Motor Factory – DESIGN area is the first environment of Motor Factory.
It is composed of four main zones. This is the guided line to design your machine.
| Motor Factory – DESIGN area view – Example for reluctance synchronous machine | |
| Zone 1 MACHINE | Definition of general data of the machine depending on the
                                    considered type of machine
| Zone 2 ROTOR | Access to the main functions to design the ROTOR mainly defined
                                        by:
| Zone 3 STATOR | Access to the main functions to design the STATOR mainly defined
                                        by:
| Zone 4 MATERIALS | Area to select all the materials required to build the machine, rotor, stator, etc. |
| Zone 5 VIEW | Visualization of the motor radial view. The winding
                                    (automatically defined) is shown. Note: Graphic functions like export picture and zoom are
                                        available on this view by right clicking on mouse (right
                                        part of the panel). See system functions, graphic management
                                        to get more information. |
