SM WF ISP IR 3PH
Wound Field Synchronous Machines - Inner Salient Pole - InnerRotor
Home page view
The Motor Factory – DESIGN area is the first environment of the Motor Factory.
For a synchronous machine with wound field inner salient poles, it is composed of four main zones. This is the guideline for designing your machine.
| Motor Factory – DESIGN area view – Example for synchronous machine with wound field, inner salient pole, and inner rotor | |
| Zone 1 MACHINE | Definition of general data of the machine depending on the considered
                                type of machine
| Zone 2 ROTOR | Access to the main functions to design the ROTOR mainly defined
                                    by:
| Zone 3 STATOR | Access to the main functions to design the STATOR and its
                                corresponding subsets:
| Zone 4 MATERIALS | Area to select all the materials required to build the machine, the rotor, and the stator |
| Zone 5 VIEW | Visualization of the motor radial view. The winding (automatically
                                defined) is shown. Note: Graphic functions like
                                    export picture and zoom are available in this view by
                                    right-clicking on mouse (right part of the panel).See system
                                    functions, graphic management to get more
                                information. |
