Thermal
Here are the temperatures to be set:
- External fluid temperature
- Cooling circuit fluid temperature
Note: The external fluid temperature corresponds to the
temperature of the fluid surrounding the machine. It is also considered as the
temperature at the “infinite” for the computation of radiation from the frame to the
infinite.
Note: The cooling circuit fluid temperature is relevant only when
a cooling circuit has been added by the user in the design environment. In this
case, this input describes its fluid inlet temperature.
Settings
For more details, please refer to Thermal for SM-WFISP
