MAGNET
Overview
| MAGNET design area | |
| 1 | Selection of the STATOR subset: MAGNET panel (Click on the icon MAGNET) |
| 2 | Visualization of the motor radial view to view the magnet topology and dimensions. |
| 3 | DESIGN tab indicates the tools to define the magnet topology and
                                    parameter values Note: By default, DESIGN
                                        tab is selected |
| 4 | POLARIZATION tab contains the tools to define the magnets polarization |
| 5 | LAMINATION tab contains the tools to define the lamination geometry |
| 6 | "Magnet shape" button allows accessing the magnet libraries to change the magnet topology. See additional information below. |
| 7 | User input parameter fields to enter the values. |
| 8 | Button to restore default input values. |
| 9 | Button to apply inputs. Pressing the “enter key” twice applies inputs too. |
| 10 | Output parameters (read only data) to complete the description of the topology. |
| 11 | Icon to export magnet data into *.txt or *.xlsx files. |
