Thermal
  • External fluid temperature
  • Cooling circuit fluid temperature
Note: The external fluid temperature corresponds to the temperature of the fluid surrounding the machine. It is also considered as the temperature at the “infinite” for the computation of radiation from the frame to the infinite.
Note: The cooling circuit fluid temperature is relevant only when a cooling circuit has been added by the user in the design environment. In this case, this input describes its fluid inlet temperature.
Settings
For more details, please refer to Thermal for IM-SQ
