Introduction to CADFEKO
Use CADFEKO to configure a solver-ready input file for Solver simulations.
CADFEKO is the Feko component that allows you to create complex CAD geometry using primitive structures (for example, cuboids and polygons) and to perform Boolean operations (for example, union and subtract) on the geometry. Complex geometry models and mesh models can be imported or exported in a wide range of industry standard formats. Reduce development time by using a component from the list of antennas and platforms in the component library.
In CADFEKO, you can request multiple solution configurations, specify calculation requests as well as specify the solution settings for the model. If an optimisation search is required, you can specify the optimisation parameters and goals.
