Setting Up POSTFEKO to View Optimisation Progress
Create a 3D view with the far field results as well as two Cartesian graph to view the distance parameter and far field goal.
Display the far field in the 3D view.
Add a Cartesian graph and view the optimised parameter,
alpha.
Duplicate the first graph (to create a second graph) to view the optimised
parameter, d.
On the Cartesian
context tab, on the Display tab, in the Duplicate group, click the
Duplicate view icon.
- In the result palette select the trace, Optimisation.
- In the result palette, in the Trace field, select d.
On the Cartesian
Duplicate the first graph (to create the third graph) and view the far field
goal versus optimisation run number.
On the 3D View
contextual tabs set, on the Display tab, in the
- In the result palette, in the Trace field, select search1.goals.farfieldgoal1.
On the 3D View
[Optional] Arrange (tile) the four windows to view the multiple windows at
once.
On the View tab, in the
Window, click the
Tile icon.
Window, click the
