When the frequency is set or local mesh settings are applied to the geometry, the
automatic mesh algorithm calculates and creates the mesh automatically while the GUI is
active using default mesh settings. When required, these mesh settings may be
modified.
Open the Modify Mesh Settings dialog using one of the
following workflows:
On the Mesh tab, in the
Meshing group, click the Modify Mesh icon.
Press Ctrl+M to use the keyboard
shortcut.
On the Modify Mesh Settings, set the Mesh
size to Coarse.
Set the Wire segment radius to
0.001.
Figure 1. The Modify Mesh Settings dialog.
Click OK to create the mesh
and to close the dialog.
