Creating the Waveguide Sections
Create the waveguide sections using two cuboids.
  1. Create the first waveguide section.
    1. On the Construct tab, in the Create Solid group, click the  Cuboid icon.
    2. Create the cuboid using the Base centre, width, depth, height definition method.
    3. Use the following dimensions:
      • Base centre (C): (0, 0, 0)
      • Width (W): wg_w
      • Depth (D): 2*wg_w
      • Height (H): wg_h
      • Label: Cuboid1
      Figure 1. The Create Cuboid dialog.
    4. Click OK to create the waveguide section and to close the dialog.
  2. Create the second waveguide section.
    2. Create the cuboid using the Base corner, width, depth, height definition method.
      • Base corner (C): (wg_w/2, -wg_w/2, 0)
      • Width (W): wg_w
      • Depth (D): wg_w
      • Height (H): wg_h
      • Label: Cuboid2
      Figure 2. The Create Cuboid dialog.
Figure 3. The two waveguide sections and power dividing pin.
