Setting a Local Wire Radius for the Monopole
Specify a local wire radius for the monopole.
The monopole and transmission line are each assigned a different wire radius. Due to the differences in the wire radii, we specify a local wire radius for the monopole.
Note: Local mesh refinement takes precedence over global mesh settings.
  1. In the model tree (Construction tab), select Monopole. In the details tree, select Wire1.
  2. From the right-click context menu, select Properties.
  3. On the Modify Edge dialog (Properties tab), specify the following:
    1. Select the Local wire radius check box.
    2. Set the Radius to 0.015.
    Figure 1. The Modify Edge dialog.
  4. Click OK to apply the properties and to close the dialog.
Note: The icon in the details tree indicate that a local wire radius is applied.
