Specify the frequency range of interest. For this example continuous frequency
sampling is used where Feko determines the frequency sampling
for optimal interpolation automatically.
On the Source/Load tab, in the
Settings group, click the Frequency icon.
On the Solution Frequency dialog, select
Continuous (interpolated) range from the drop-down list.
Specify the frequency range between 1 MHz and
30 MHz.
Enter the start frequency and end frequency.
Start frequency (Hz):
1e6
End frequency (Hz):
30e6
Figure 1. The Solution Frequency dialog.
Click OK to specify the frequency and to close the
dialog.
