Define a wire port on the feed pin. A voltage source will be added to this
port.
Note:A port is a mathematical representation of where energy can
enter (source) or leave a model (sink). Use a port to add sources and discrete loads to
a model.
Open the Create Wire Port dialog using one of the
following workflows:
On the Source/Load tab, in the
Ports group, click the Wire Port icon.
In the details tree, a right-click context menu is available on the wire. From the list, click Create port > Wire Port.
Select the wire where the port is to be added.
In the model tree, select
feed_line.
In the details tree, select the wire of
feed_line.
Under Location on wire, select
Start.
Figure 1. The Create Wire Port dialog.
Click Create to create the port and to close the
dialog.
