Macro Recording of Example 3
The CADFEKO macro recorded Lua script for Example 3 is given below.
application = cf.Application.getInstance()
-- NewProject
project = application:NewProject()
-- SetProperties
properties = application.Project.ModelAttributes:GetProperties()
properties.Unit = cf.Enums.ModelUnitEnum.Millimetres
application.Project.ModelAttributes:SetProperties(properties)
-- Add
properties1 = cf.Variable.GetDefaultProperties()
properties1.Expression = "18.8"
properties1.Label = "patch_size"
patch_size = application.Project.Definitions.Variables:Add(properties1)
-- Add
properties1.Expression = "4.3"
properties1.Label = "chamfer_d"
chamfer_d = application.Project.Definitions.Variables:Add(properties1)
-- Add
properties1.Expression = "-6.4"
properties1.Label = "feed_pos"
feed_pos = application.Project.Definitions.Variables:Add(properties1)
-- Add
properties1.Expression = "45"
properties1.Label = "substrate_w"
substrate_w = application.Project.Definitions.Variables:Add(properties1)
-- Add
properties1.Label = "substrate_d"
substrate_d = application.Project.Definitions.Variables:Add(properties1)
-- Add
properties1.Expression = "5"
properties1.Label = "substrate_h"
substrate_h = application.Project.Definitions.Variables:Add(properties1)
-- Add
properties1.Expression = "5.6"
properties1.Label = "ceramic_epsR"
ceramic_epsR = application.Project.Definitions.Variables:Add(properties1)
-- Add
properties1.Expression = "0.0041"
properties1.Label = "ceramic_tanD"
ceramic_tanD = application.Project.Definitions.Variables:Add(properties1)
-- CreateGroup
group1 = application.Project.Definitions.Variables:CreateGroup()
-- MoveIn
group1:MoveIn({patch_size, chamfer_d})
-- Setting Label
group1.Label = "Patch"
-- CreateGroup
group11 = application.Project.Definitions.Variables:CreateGroup()
-- MoveIn
group11:MoveIn({substrate_w, substrate_d, substrate_h})
-- Setting Label
group11.Label = "Substrate"
-- AddDielectric
properties2 = cf.Dielectric.GetDefaultProperties()
properties2.DielectricModelling.RelativePermittivity = "ceramic_epsR"
properties2.DielectricModelling.LossTangent = "ceramic_tanD"
properties2.Label = "Ceramic"
ceramic = application.Project.Definitions.Media.Dielectric:AddDielectric(properties2)
-- Setting Colour
ceramic.Colour = "#aa55ff"
-- AddPolygon
properties3 = cf.Polygon.GetDefaultProperties()
properties3.Corners[1].U = "patch_size"
properties3.Corners[1].V = "patch_size"
properties3.Corners[1].N = "substrate_h"
properties3.Corners[2].U = "-patch_size + chamfer_d"
properties3.Corners[2].V = "patch_size"
properties3.Corners[2].N = "substrate_h"
properties3.Corners[3].U = "-patch_size"
properties3.Corners[3].V = "patch_size - chamfer_d"
properties3.Corners[3].N = "substrate_h"
properties3.Corners[4] = {}
properties3.Corners[4].U = "-patch_size"
properties3.Corners[4].V = "-patch_size"
properties3.Corners[4].N = "substrate_h"
properties3.Corners[5] = {}
properties3.Corners[5].U = "patch_size - chamfer_d"
properties3.Corners[5].V = "-patch_size"
properties3.Corners[5].N = "substrate_h"
properties3.Corners[6] = {}
properties3.Corners[6].U = "patch_size"
properties3.Corners[6].V = " -patch_size + chamfer_d"
properties3.Corners[6].N = "substrate_h"
properties3.LocalWorkplane.WorkplaneDefinitionOption = cf.Enums.LocalWorkplaneDefinitionEnum.UsePredefinedWorkplane
globalXY = application.Project.Definitions.Workplanes:Item("Global XY")
properties3.LocalWorkplane.ReferencedWorkplane = globalXY
properties3.Label = "patch"
patch = application.Project.Contents.Geometry:AddPolygon(properties3)
-- AddCuboid
properties4 = cf.Cuboid.GetDefaultProperties()
properties4.Origin.U = "-22.5"
properties4.Origin.V = "-22.5"
properties4.Width = "substrate_w"
properties4.Depth = "substrate_d"
properties4.Height = "substrate_h"
properties4.LocalWorkplane.WorkplaneDefinitionOption = cf.Enums.LocalWorkplaneDefinitionEnum.UsePredefinedWorkplane
properties4.LocalWorkplane.ReferencedWorkplane = globalXY
properties4.Label = "substrate"
substrate = application.Project.Contents.Geometry:AddCuboid(properties4)
-- SetProperties
properties5 = substrate.Regions:Item("Region1"):GetProperties()
properties5.Medium = ceramic
substrate.Regions:Item("Region1"):SetProperties(properties5)
-- AddLine
properties6 = cf.Line.GetDefaultProperties()
properties6.StartPoint.V = "feed_pos"
properties6.EndPoint.U = "0"
properties6.EndPoint.V = "feed_pos"
properties6.EndPoint.N = "substrate_h"
properties6.LocalWorkplane.WorkplaneDefinitionOption = cf.Enums.LocalWorkplaneDefinitionEnum.UsePredefinedWorkplane
properties6.LocalWorkplane.ReferencedWorkplane = globalXY
properties6.Label = "feed_line"
feed_line = application.Project.Contents.Geometry:AddLine(properties6)
-- AddUnion
union1 = application.Project.Contents.Geometry:Union({patch, substrate, feed_line})
-- SetProperties
properties7 = union1.Faces:Item("Face8"):GetProperties()
perfectElectricConductor = application.Project.Definitions.Media.PerfectElectricConductor
properties7.Medium = perfectElectricConductor
union1.Faces:Item("Face8"):SetProperties(properties7)
-- ToggleVisibility
substrate.Faces:Item("Face2"):ToggleVisibility()
-- ToggleVisibility
-- SetProperties
properties8 = union1.Faces:Item("Face6"):GetProperties()
properties8.Medium = perfectElectricConductor
union1.Faces:Item("Face6"):SetProperties(properties8)
-- AddWirePort
properties9 = cf.WirePort.GetDefaultProperties()
edge19 = feed_line.Edges:Item("Edge19")
properties9.Wire = edge19
properties9.Label = "Port1"
port1 = application.Project.Contents.Ports:AddWirePort(properties9)
-- AddVoltageSource
properties10 = cf.VoltageSource.GetDefaultProperties()
properties10.Terminal = port1
properties10.Label = "VoltageSource1"
voltageSource1 = application.Project.Contents.SolutionConfigurations.GlobalSources:AddVoltageSource(properties10)
-- SetProperties
properties11 = application.Project.Contents.SolutionConfigurations.GlobalFrequency:GetProperties()
properties11.Start = "1.27e9"
properties11.End = "1.85e9"
properties11.RangeType = cf.Enums.FrequencyRangeTypeEnum.Continuous
application.Project.Contents.SolutionConfigurations.GlobalFrequency:SetProperties(properties11)
-- SetProperties
properties12 = application.Project.Mesher.Settings:GetProperties()
properties12.MeshSizeOption = cf.Enums.MeshSizeOptionEnum.Fine
properties12.WireRadius = "07"
properties12.Advanced.GrowthRate = 30
properties12.Advanced.RefinementFactor = 80
properties12.Advanced.MinElementSize = 80
application.Project.Mesher.Settings:SetProperties(properties12)
-- ToggleVisibility
application.Project.Contents.Cutplanes:Item("XZ-Cut"):ToggleVisibility()
-- ToggleVisibility
-- SetProperties
properties13 = union1.Edges:Item("Edge6"):GetProperties()
properties13.LocalMeshSizeEnabled = true
properties13.LocalMeshSize = "2"
union1.Edges:Item("Edge6"):SetProperties(properties13)
-- SetProperties
properties14 = union1.Edges:Item("Edge3"):GetProperties()
properties14.LocalMeshSizeEnabled = true
properties14.LocalMeshSize = "2"
union1.Edges:Item("Edge3"):SetProperties(properties14)
-- Add
properties15 = cf.FarField.GetDefaultProperties()
properties15.Theta.End = "180.0"
properties15.Theta.Increment = "5.0"
properties15.Phi.End = "360.0"
properties15.Phi.Increment = "5.0"
properties15.Label = "FarField1"
properties15.LocalWorkplane.WorkplaneDefinitionOption = cf.Enums.LocalWorkplaneDefinitionEnum.UsePredefinedWorkplane
properties15.LocalWorkplane.ReferencedWorkplane = globalXY
farField1 = application.Project.Contents.SolutionConfigurations:Item("StandardConfiguration1").FarFields:Add(properties15)
-- SaveAs
application:SaveAs("C:/Users/eh/Desktop/Example2.CADFEKO")
