A model is parametric when it is created using variable expressions. When a variable
expression is modified, any items dependent on that variable are re-evaluated and
automatically updated. It is the recommended construction method when creating a
model, but not compulsory.
Defined variables are stored as part of the model in the .cfx
file.
Open the Create Variable dialog using one of the
following workflows:
On the Construct tab, in the Define group, click the Add Variable icon.
On the model tree, a right-click context menu is available on Variables. From the
list, select Add Variable.
Figure 1. The model tree
(Construction tab).
On the model tree, click the icon. From the drop-down list, select Add Variable.
Figure 2. The drop-down list available in the model tree.
Press # to use the keyboard shortcut.
Create the following variables:
Name
Expression
Comment [Optional]
Width
1
Width of rectangle.
Length
1
Length of rectangle.
BottomDepth
1
Bottom depth of flare.
BottomWidth
1
Bottom width of flare.
FlareLength
1
Length of flare.
TopWidth
2
Top width of flare.
TopDepth
2
Top depth of flare.
Figure 3. The Create Variable dialog.
Tip:
Click Add to keep the Create Variable dialog open and add more
variables.
Click Create to add a variable and
close the Create Variable dialog.
