Create a rectangle to be used in the construction of the horn.
On the Construct tab, in the Create Surface group, click the
Rectangle icon.
Figure 1. The Create Rectangle dialog.
Note: Default values are used on geometry creation dialogs
to allow a preview in the 3D view. You may change the
values as required.
Tip: An active field allowing point-entry is indicated by a
yellow outline.Point-entry allows a variable or named points to be
entered by pressing Ctrl+Shift+left click on a
variable or named point in the model tree.
Create a rectangle using the Base centre, width, depth
definition method.
Use the following dimensions:
- Base centre (C): (0, 0, 0)
- Width (W): 1
- Depth (D): 1
Click Create to create the rectangle and to close
the dialog.
Figure 2. The rectangle created using Workplane1.
