Viewing the Near Field Results (3D)
View the near field results in the 3D view and add a legend and contours.
Add the near field data to the 3D view.
View the magnitude of the Ey component of the field.
View the electric field in dB.
- On the result palette, in the Quantity panel, select the dB check box.
Add a legend to the 3D view (top left).
On the 3D View
contextual tabs set, on the Display tab, in the
Legends group, click the
Top left icon. From the drop-down list select NearFields.
On the 3D View
Add contours to the near field result.
On the 3D View
contextual tabs set, on the Result tab, on the
Contours group, click the
Show contours icon.
On the 3D View
Specify the number of contours for the near field.
![](../../../../images/feko/getting_started_guide/horn_rectangular/view_near_field.png)
Figure 4. The near field results with contours.
