Viewing the Near Field Results (2D)
Create a new Cartesian graph. Create two near field traces and compare the Ey and Ex components of the near field along the X direction.
On the Home tab, in the
Create new display group, click the
Cartesian icon.
Add the near field result to the Cartesian graph.
Add results group, click the
Near Fields icon. From the drop-down list, select NearField1.
View the near field along the X direction.
On the result palette, in the Slice panel, make the following changes:
- From the Independent axis (Horizontal) list, select X position.
- From the Frequency list, select 1.645 GHz.
- From the Y position list, select 100 mm.
- From the Z position list, select 460 mm.
Figure 1. The Slice panel in the result palette.
View the magnitude of the Ey component of the field.
Quantity panel, clear the
X check box and the
Z check box.
Figure 2. The Slice and part of the Quantity panels in the result palette.
X check box and the
Z check box.
Add a second trace to the Cartesian graph by duplicating
the NearField1 trace.
On the Trace tab, in the
Manage group, click the
Duplicate trace icon.
A second trace, NearField1_1, is created. -
View the magnitude of the Ex component of the field.
- On the result palette, select the NearField1_1 trace.
- On the result palette, in the Quantity panel, select the X check box and clear the Y check box.
Set the vertical axis to dB.
- In the result palette, select both traces (NearField1 and NearField1_1).
- In the Quantity panel, select the dB check box.
Modify the minimum and maximum values for the vertical axis.
On the Cartesian
context tab, on the Display tab, on the Axes group, click the
Axis settings icon.
- On the Axis settings (Cartesian graph) dialog, select the Vertical tab.
- Clear the Automatically determine the grid ranges check box.
- In the Maximum value field, enter a value of 40.
In the Minimum value field, enter a value of
-20.
Figure 3. The Axis settings (Cartesian graph) dialog. - Click OK to close the dialog.
Figure 4. The Ey and Ex components of the near field along the X direction. -
On the Cartesian
