Topics Discussed in this Example
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
The topics discussed in this example are:
- View the Feko general workflow.
- Launch CADFEKO.
- View the CADFEKO layout.
- View the POSTFEKO layout.
- View the far field results and near field results in POSTFEKO.
Note: Follow the example steps in the order it is presented
as each step uses its predecessor as a starting point.
1 The application
macro library is located on the Home tab, in the
Scripting group. Click the Application Macro
icon and from the drop-down list, select Getting Started
Guide.
