Split/Combine Morph Volumes
Use the Morph Volumes: Split/Combine tool to split morph volumes using a single or multiple locations along an edge, combine adjacent morph volumes along shared faces, join pairs of separate morph volumes, or equivalence any number of morph volume faces using a search distance.
                From the Morph ribbon, click the Morph Volumes > Split/Combine tool.
Figure 1. -
                Choose the operation to perform from the guide bar.
Option Description Split Pick a split location on a morph volume edge using the mouse. Reposition the split location using snaps, or use the microdialog to change number of splits.
 - Toggle between splitting the selected
                                edge with a single cut
 or multiple cuts
. Use the text box to adjust the
                                position of a single cut as a ratio of the edge length, or adjust
                                the number of multiple cuts
 - Enforce tangency
                                of the adjacent volumes after the split.
 - Generate morph handles at the
                                vertices of the split location (recommended). Disabling this option
                                will not allow any morphing of the vertices, edges, or faces at the
                                split location.Combine Combine rows of adjacent morph volumes that share a common face. Use the microdialog to toggle tangency of the new combined volume with its neighbors.
 - Enforce tangency
                                of any adjacent volumes after the combination.
 - Keep morph handles at the vertices of
                                the combined location.Join Join morph volumes that don't share a common face. Use the microdialog to choose the join location and toggle tangency.
 - Choose the location to join the
                                volumes. Either move the faces of both volumes to their midpoint, or
                                keep the face of the first or second selected volume.
 - Enforce tangency
                                of the newly joined volumes.
 - Automatically
                                register any new inner nodes to their respective enclosing volumes
                                after they are joined.Equivalence Bulk join any non-adjacent morph volumes that have faces within the specified search distance. Use the microdialog to optionally restrict the search to only selected volumes, and toggle their new tangency.
 - Use this button to optionally select
                                candidate volumes to equivalence. If left empty all volumes are
                                considered candidates.
 - Enforce tangency
 - Automatically
                                after they are joined. -
                Click the action button
                    in the microdialog to confirm the operation.
