Morphing Preferences
Define morphing preferences.
- From the File menu, select .
 - From the Morph ribbon, click the
                            Options tool.
Morphing
| Option | Action |
| Use symmetry links | Create links between
                                    symmetric handles active or inactive for all symmetries.  When not selected, morphing the model behaves differently. Reflective symmetries (1-plane, 2-plane, 3-plane, and cyclical) are completely ignored, while non-reflective symmetries no longer link handles but still affect node influences. Select Use symmetry links to reactivate them for subsequent morphs in which you need symmetry.  |
| Use constraints | Turn your constraints
                                    on and off without changing their active status.  If selected, constraints will not be applied to the model while morphing. If selected, only the active constraints will be applied during morphing. This allows you to perform some morphing options without using any constraints, and then reactivate the constraints for further morphing.  |
| Elements mid-nodes | Choose a method for
                                    handling second order element mid-nodes.
| Minimum step size (distance) | Specify the minimum step size (in model units) used during interactive morphing. All morphing applied using interactive methods, such as using a manipulator, dragging a handle along a vector, or dragging a handle across a surface, will be rounded to the nearest multiple of the minimum step size before being applied to the handles. Thus, setting the minimum step size distance to 1.0 will force the handle to be morphed in steps no less than 1.0, such as 2.0, 3.0, 6.0 and so on. These steps will be reflected in the movement of the handles across the screen, which will occur in discrete increments. |
| Minimum step size (angle) | Set the minimum step size (in degrees) for interactive morphing. |
| Handle bias style |
Auto QA
| Option | Action |
| Element quality check | Evaluate element quality after every morphing operation, including the application of constraints when they are created. |
| Auto smoothing | Choose the type of
                                    smoothing applied after morphing.
 Note: Smoothing in real time can be slow for
                                        large meshes.
| Auto remeshing | Select when remeshing
                                    after morphing occurs. For both manual and on release remeshing,
                                    select the mesh type (quads, trias, mixed, or r-trias), the
                                    target element size, and whether you want size control, skew
                                    control, to preserve shapes, and whether or not to also remesh
                                    3D elements.  For automatic remeshing on release, there is a
                                        text box labeled qa fail% >. This value represents the
                                        percentage of affected elements that have to fail the auto
                                        quality check before remeshing is triggered.
Note: Automatic remeshing will not be active
                                            unless automatic quality check is turned on, as the
                                            automatic quality check is used to supply the current qa
                                            fail%.
During automatic remeshing (which is
                                        active when you select the on release option), watch
                                        carefully as new messages are written to the screen after
                                        morphing. After highlighting the elements which failed the
                                        auto qa, if the number of failed elements exceeds the qa
                                        fail %, you will see the message, "QA - right click
                                            to remesh," instead of simply,
                                            "QA" written either next to your cursor
                                        or in the bottom-right corner of the window. If you
                                        right-click, all affected domains and elements will be
                                        remeshed. If you left-click, remeshing will not occur. Once
                                        the remesh is complete, you will see the message,
                                            "remesh - right click to reject." This is
                                        your only chance to reject the remeshing that has been
                                        performed. If you right-click, the remeshing will be
                                        rejected and the morphing will be retained. If you
                                        left-click, the remeshing cannot be undone, although the
                                        morphing can be.
Note: An affected element is any
                                            element that touches a node that has been morphed,
                                            whether or not it has failed QA. An affected domain is
                                            any domain that contains an affected
                                    element.
Connectors, Clusters, Equations
| Option | Action |
| Morphing mode | Choose how connectors,
                                    cluster domains, and equations are treated.
| Rotation mode | Choose the rotation
                                    applied to any connectors or equations treated as clusters, or
                                    to cluster domains.
| Stretch mesh around connectors, clusters, and equations | Ensure that the
                                    surrounding mesh transitions smoothly when clusters are
                                        morphed. Note: Due to the rigid body movement of
                                        clusters, morphing performed on a mesh connected to one end
                                        of a cluster will move that cluster and affect unmorphed
                                        meshes connected to the cluster. If mesh stretching is
                                        active, morphing will be applied to the unmorphed meshes as
                                        well.
| Option | Action |
| Global influences | Choose whether global
                                    domains and morph volumes will affect nodes within them
                                    directly, hierarchically, or by a mixed method.
| Save morph list with file | Save any morphs on the undo/redo list in the model file along with the morphs that have been applied to the model. When the model is reloaded, the undo/redo list will be restored and you will be able to undo and redo the morphs on the list in the same way that you could when you saved the file. If the model was saved with morphs already applied to the model, you will be able to undo them after reloading the model to get back to the original shape. |
Domain Solvers
| Option | Action |
| Large domain morphing | Choose when to perform
                                    the morphing of large domains.
 If elements become folded during morphing, choose how to
                                        trigger the automatic unfolding and optimization step.
                                        Unfolding can be compute-intensive depending on the number
                                        off elements involved.
| Small domain solver | Choose how the
                                    morphing of small domains is performed.
 For standard or kriging methods you may set autofix squashed domains to either off, on release, or real time. When set to on release or real time, this option will automatically try to unfold any domains which get folded during morphing. When set to on release, the unfolding operation will occur after each morphing operation is applied but not during interactive morphing. When set to real time, the unfolding operation will occur after each morphing operation is applied as well as during interactive morphing. For either linear static or nonlinear
                                        explicit morphing, additional options are available.
| Kriging | Choose when kriging is
                                    performed for domains and morph volumes.
FEA Results
| Option | Action |
| FEA results | Choose the frequency
                                    of the results display.
 Note: In order to use interactive FEA
                                        results, you must set up your model with all the necessary
                                        cards to do an analysis for one of the following types:
                                        Linear Static, Nonlinear Explicit, Stamping 1-step, or
                                        Stamping incremental. HyperMorph
                                        will not alter your model in any way in order to solve it.
                                            HyperMorph will simply write
                                        out a data file with the prefix "morphfea" and invoke the
                                        specified solver. Errors during the solution process can be
                                        found in output files located in the current working
                                        directory.
| Plot | Choose between contour plot and assign plot when displaying the FEA results. |
| Maximum plot value | Used when displaying
                                    the results.  Select whether to let the software determine the maximum result, or specify the maximum result that is relevant to your task.  |
| Minimum plot value | Used when displaying
                                    the results.  Select whether to let the software determine the minimum result, or specify the minimum result that is relevant to your task.  |
| Plot value | Used when displaying
                                    the results.  Select whether to display the total magnitude or the X, Y, Z components of the results.  |
| Mesh color | Used when displaying
                                    the results.  Select the color that the results mesh is drawn.  |
| Min/Max titles | Used when displaying
                                    the results.  Display text/number titles for the minimum and maximum results in the modeling window.  |
| Info title | Used when displaying
                                    the results.  Display an informational title in the modeling window.  |
| FEA solver | Set the solver used
                                    for FEA results.
