Set Biasing
Change the biasing factors associated with each handle.
- From the Morph ribbon, click the arrow next to the Morph tool set name and select Set Bias.
                In the Morph Set Bias dialog, select handles for which you
                    wish to apply biasing and click
             - For Bias, enter a value.
 - Select the Make Retroactive check box to adjust the morphs currently applied to the model to reflect the new biasing factors.
 - Select a biasing style.
 - Click Update.
