Move Morph Volumes
Use the Morph Volumes: Move tool to morph or adjust morph volumes by moving vertices/handles, edges, and faces with graphical manipulators.
                From the Morph ribbon, click the Morph Volumes > Move tool.
Figure 1. - Optional:
                On the guide bar, click
 to modify enclosing options.
                Select vertices, edges, or faces then use the arrow manipulators to move
                    them.
                Registered mesh will morph along with the volume as it moves.
Click
 to access a full range manipulators. - Optional:
                Use the guide bar to switch modes between
                        Morph and Adjust Volumes as
                    needed.
- Morph
 - Morph all registered nodes and connectors inside the morph volumes by moving their faces, edges, or vertices.
 - Adjust Volumes
 - Reposition morph volume faces, edges, or vertices without morphing their contents.
