Check or Smooth Shapes
Use the Check/Smooth function to check the element quality of shape combinations and optionally smooth the shapes to improve the element quality when applied individually or as part of a combination of shapes.
The check and smooth functionalities are intended to make shape optimization more productive. Shape optimization solvers, like Radioss, will stop iterating if the element quality falls below certain limits. The check and smooth functions help to improve the element quality when shapes are applied simultaneously as well as calculate the maximum and minimum bounds at which the shapes can be applied to ensure successful completion of an optimization run.
Element quality limits
Trias
  Test                Warning     Error     Invalid
    Aspect ratio        50.000    500.000  10000.000
    Skew                75.000     85.000     90.000
    Minimum angle       15.000      3.000      0.000
    Maximum angle      165.000    177.000    180.000
    Warpage            -------    -------    -------
    Tetra collapse     -------    -------    -------
    Jacobian           -------    -------    -------The second section of the report file contains one sub-section for each combination of the selected shapes. Each sub-section will contain a list of the selected shapes and the multiplier applied to each one for the given combination. Each sub-section will also contain the value of the worst element quality for each of the following active tests: aspect ratio, skew, minimum angle, maximum angle, warpage, tetra collapse, and jacobian. The worst result for each test is measured against the element quality limits to determine whether an optimization run will give a warning or an error, and if so it will be noted in the given sub-section along with the offending element ID and the element test limits for that element type.
Combination 15
  Shape        2 applied at   1.0000
  Shape        3 applied at   1.0000
  Shape        4 applied at   1.0000
  Shape        5 applied at   0.0000
  ***** warning - poor element quality *****
  Aspect ratio      4.240
  Skew             60.303   Elem id 112   Limits:  60.000   75.000   90.000
  Minimum angle    26.718
  Maximum angle  158.141
  Warpage           0.000
  Tetra collapse    1.000Optimization errors can be avoided using the following limits:
  Shape        2  upper bound   0.9230   lower bound   0.0000
  Shape        3  upper bound   0.8680   lower bound   0.0000
  Shape        4  upper bound   0.9230   lower bound   0.0000
  Shape        5  upper bound   0.8680   lower bound   0.0000If you set
                the upper and lower bounds on your DESVARs to these values, the optimization run
                should not encounter any errors due to element quality regardless of the combination
                of shapes applied.
