Animate Shapes
Animate selected shapes.
                From the Morph ribbon, click the Shapes tool.
Figure 1.The Edit Shapes dialog opens. - Select a shape.
                Click
                The Edit Shapes dialog closes and the Shape Animation toolbar displays.
Figure 2. -
                Set playback options as necessary by clicking
                - Set Playback to loop, bounce, or once.
 - Place a check in the Contour Plot checkbox to display the plot.
 - Type a value for the desired number of frames.
 - Type a value for the Animation speed.
 - Type a value for Scale factor. This will change the height of the animation.
 - Play, pause, or rewind the animation using the playback tools on the toolbar.
                Redisplay the model in its current shape factor by clicking
                To return to the Edit Shapes dialog, click
